1 - 1 of 1 Posts
Well I have had an ongoing issue with the interior lights staying on. Lights are supposed to go out after a minute or two after closing door or when car is running. Anyway I have read that removing and cleaning green box in footwell area can help problem. What I have done is remove fuse for interior lights to alleviate the problem. However the power door lock switch is on the same fuse so I have to manually lock all doors. But today I removed green box cleaned with crc electrical cleaner and set it aside to dry. I went ahead and put fuse back in for interior lights. Now everything seems to work perfectly. The lights go out after a minute or 2,and they go out once the door is closed and vehicle is running. I'm going to put green box back in to see what happens, but will anything bad happen if it is left out?.
1 - 1 of 1 Posts
