1 - 20 of 20 Posts
I was trying to install a LED light and it seemed to have shorted out all my interior lights...even the HVAC lights, but not the dash cluster.
I checked the fuses and they are good. I tried putting the old bulbs back in and diff. newer LEDs and nothing.
Am I missing a fuse?
And by missing a fuse, I mean did I not locate something?
Anyways I tested it, and the column of fuses all the way to the right (all 10A) do not have power going to them, although everything works but the int lights. That fuse says INT DIM (this is int. lights correct?)
Front/Rear lights work and are on that same "bank" that doesn't seem to be getting power. Weird.
On my car (92 capi wagon) it was on the same fuse as the power locks for some reason. (I think anyway its been so long) but it was a 15 amp fuse. Took me about 2 days to find it because it wasnt in the correct (or atleast what I thought was correct) slot.
my question to you is how did you do that on a led install? what were you trying to install exactly?
Something shorted when I was trying to install dome light. It was weird, but I didn't disconnect the battery or anything. Never had an issue ever when doing electrical.
Still out. Disconnecting the battery did nothing, except reset my stereo settings. cwm1
Now I noticed my drivers master lock switch doesn't work. Neither does the passenger side.
But my alarm remote will lock each one, except for the drivers front door.
I think the short, is the cause of all these problems.
So since the right column of the fuse panel doesn't seem to be getting power, any suggestions?
Discussion Starter · #9 ·
Ah, forgot about this post...me too.
Which slot, do you remember?
^^^Damn that's som Yoda talk there.
Appreciate, I do, any information, have you. :D
I'm running on low fumes = little sleep/food. cwm3
Did you check your fusable links? There are 3-4 under the hood.
Think he's talking about the one on the drivers side with the 3 big silver ones and 4 fuses below it.
I am referring to the fusable links, which look like wires with heat shrink tubing around them. They are sometimes yellow, but can be red, brown, or black. If you check your FSM you can find them. They are usually hooked up in the circuit before any fuse block. They are in "always hot" circuits.
Get your VOM out and start checking for voltage.
Discussion Starter · #14 ·
I don't have a full service manual. Going to look under the hood now...perhaps you can reply with a specific location in case I can't find them.
Discussion Starter · #15 ·
This yellow thing?
I unplugged it and tried testing for voltage and nothing. I put the tester on one of the two "prongs" while I had it disconnected. Was this correct?
That is the connector for your antilock brake sensor.
I have a 91 and 92, so I do not know exactly where the fusable links are. You should use your VOM to check for 12 volts. You can follow the circuit to the door switches, and other locations. I can not give you the schematics, because they are a little different from the 91-92 cars. You really need the schematics to determine the wire locations, and connectors.
You can check for voltage at all the "hot at all times" fuses on the battery side. If you do not get voltage on one, that is the wire you have to chase.
Over the forum I am limited to the info I have given you at this time. Now you need to get to work and do the troubleshooting.
Discussion Starter · #17 ·
Anyone with a 96 know? Like I said no power to fuses on right side of the panel by drivers side door.
I don't want to tear apart the dash to chase wires when I can pinpoint it using someones experience of a diagram. :D
Discussion Starter · #18 ·
fixed, was looking for a 10A fuse, not 25A.
I missed the 25A when I looked at every fuse because the fuse didn't blow like I've seen in past. Hairline fracture.
so KGee ... got the same problem in my wagon... the power locks 15A blows everytime I engage the locks but the bottom row or the far right row with int dim and stuff *10A's) all do not get power.. do u know what that might be bro?
Same problem. My visor vanity light wire was the cause.
1 - 20 of 20 Posts
