Ok, so did the Hotchkis but didn't like the stance (not enough drop), so I ended up with a set of Intrax springs. Does anyone have any tips? One thing I noticed is that they don't look progressive like the Hotchkis springs, all the coils are wound the same, not closer together at one end. Also, they don't have any writing or anything stamped on them so I'm not sure which end is the top and which is the bottom?
The fronts are linear, rears are progressive.
I don't think the fronts have a "flatter" coil on one end like stock (and other springs) to signify a top or a bottom. If this is indeed the case, then they can be put in any direction. The overall install procedure would be the same as any other springs; and is actually a bit easier than with other springs due the short height of the Intrax).
