1 - 20 of 33 Posts
Finally got around to update the old stereo system.
First to go was the Head unit
Installed:
Latest & Greatest Ipad 4... 128 gb... wifi/4g
12V HT Istreamer from 30 pin Lighting output pin to an RCA to:
Audio Control Line driver Parametric EQ...used as a volume button/ EQ settings
I am slowly adding pics...trying to figure out this PhotoBucket deal
ipad intall
can you see my Turn on Button?
sorry for bad pics...Iphone...sucks
Ruff Stage...Installer said that insatlling ipad in Impala was easy...for permanant mount atleast. He said he didnt shave any material off the surroundings...just middle part...and AC vents were very close...need a 90 degree lighting cable for sure
AC Relocate
Needed to relocate AC....moving to Glove box is easy...dont need to extend cables...but to center console...needed a little ingenuity!!!
more pics
Discussion Starter #10 (Edited)
Yes...4.1...help with noise...high Voltage driver...over 11V...i think...no noise out of Ipad now
I had a Genius by the Name of Jay at Pacific Car Stereo/Riverside CA install it
Great Work...Honest...Great Price...Tell Joe/Owner...Twin Turbo Scott sent you!!!
Awesome! Love it
Thank you
Thanks so much....wait till you see/hear it...in Vegas....im redoing system...Dynaudio sponsored. 22-speakers...all high end Dynaudio...cant wait to meet everyone in the clubs and Vegas clubs...see you guys out there
Fasho see ya then!! :)
Sent from AutoGuide.com Free App
Discussion Starter #16
yes...thats correct
wwwdotanthony...yes...you are correct....not sure on size of the Tab compared to the Ipad...but I do think its very similar....we had to buy a special adaptor from Soundman in CA.....a 90 degree lightning adaptor...from there...we did a lightning cable to usb cable to the 12V Streamer....then a regular RCA from streamer to eq....we had to use audio control...because I think its the only parametric eq...with volume and high Voltage output...we tried a ppi eq...and it had noise... normal eq has only 4v output...audiocontrol had 11v output...which is needed for Computer install without installing a radio for volume knob...hope that helps? ive also read that a pure I20 also works well...both of I20 and Istreamer make the Ipad sound better and best of all...charge your ipad...when in USE...kills two birds with one simple plug in solution.....cool?
Beautiful work! I need to figure out where to put my HVAC controls, as I used my center area for gauges, and I have my head unit in a pod where the ashtray would go.
Did the lines fit, or did you need to run extensions of some kind? Can you give me any details?
Thanks, and congrats on a great result.
Turn on button is great! I had to look twice...
Sent from AutoGuide.com App
Discussion Starter #18
AC relocation
ocala....yes...i had to move my AC as well.....my installer said that moving it into the Glove box...didnt require much fab work...didnt have to extend anything...but everyone does that?
i moved mine to the center console...he said everything extends easily but the fan control...it required a mechanical connection....he used a choke/throotle cable setup...i will show you as much pics as i have...to try and help...ok?
Discussion Starter #19
ac relocation pics
here are some Iphone pics...sorry...small
Discussion Starter #20
ocala......hope you get an idea...of whats involved?
1 - 20 of 33 Posts
