Administrator
Mount a cheap Wal Mart 2 channel amp on the inner fender behind the washer tank. Splice the amp on feed into the power antenna on feed (or, a switched 12V source). Put a couple waterproof marine speakers in a plastic box, and mount that under the splash shield (the part the air dams attach to). Connect the speakers to the amp. Run a set of RCA cables inside to the console/ashtray/glove box/whatever and add a mini jack adapter. Plug in your Ipod, and amaze your neighbours.
Or if you currently have a system and the amp powering your interior speakers is easily accessed.
You could just run a duplicate set of wires to the front from your existing amp, and swap them over for car shows. Etc..
This way you still have the interior front or rear (depends which you unplug) speakers playing, and you don't need to purchase another amp.
