·Hi I plan a moderate spring drop on my 9C1 caprice. How much is enough to notice and how much too much drop for the street? I was thinking of a 1-2" drop.I do plan on drag racing this car so I ws thinking of cutting one coil off the bottom of fronts and using Moog cc627's on the back.This would give a fairly soft spring for racing.Also I already have new 1" shorter shocks that would work good. When I cut the fronts doesn't this leave the spring end at a wrong angle? Where you would have to heat and bend it to make it sit flat again? I know heating isn't a good idea but hows it going to fit? Or is it better to just go with a set of progressive rate type springs maybe like Vogtland [1.5" drop] or hotchkis [1.8 drop]? Thanks Tim
