1 - 9 of 9 Posts
Ok, so this has happened twice so now I'm worried. When I'm driving, my digital dash will flicker off, the gas needle will jump to full, and the engine will start to lose power almost to the point of turning off... TAP the digital cluster, lights come back on and the car goes back to running. Any ideas? PS...is a ECM and PCM the same thing? And can I trust products from RMSautoparts.com?
10-4, so you think I can rule out my computer dying?
Will do!
Computer generally works or doesn't work, I agree that a bad electrical connection is probably to blame. In addition to what has been mentioned, I'd also have a look at the connections at the ignition switch (it's down on the steering column near brake pedal, connected to the key cylinder via a metal rod)
I've ordered items from RMS before and I've been happy with their service.
1 - 9 of 9 Posts
