Will an LT4 damper bolt up and properly line up with all the accessories using the stock hub?
My stock damper disintergrated last night and I have an LT4 damper sitting in the garage. The dampers are slightly different which is why I'm asking.
Thanks.
Thanks.
Noel, I think you're going to need spacers
Just to be clear I believe Matt means accessory bracket spacers which Karl should have in stock. I am not sure about the hub.
I've got one for my stroker build-up - requires the accessory bracket to be spaced outwards 16mm to line up - full kit of 8 spacers from Karl was 40 or 50 bux - he had plenty in stock last i knew 2 months ago - hit him up he's top notch customer service wise - i'm sure he'll get 'em to you quickly - much cheaper than buying another damper and will eliminate the need for a notched passenger side valve cover if you ever wanted to change in the future
Noel Ellwein racing engines has specialty spacers that you use to make it work. The bolts that bolt the accessroy bracket to the head get spaced out 16mm. Give karl a call. they are uber cheap too.
Thanks guys.. I put it on last night. I had already spaced out the accessory bracket for the tall valve covers years ago... So it was a bolt on for me.
Thanks for the replies and i'm sure this will help someone else.
