T
The best test is to take note of the stock speaker harness and hook up some wire to the stock speaker. If you hook up a AA battery to the speaker, + to + and - to - will push the cone out. reverse it and you will pull the cone in. So that way you can tell witch is the postive and witch is the negative or do I have this backwards.
Try to fit speakers in my Ram.
J
I believe that is correct. Doesn't really matter as long as the mids are in phase.
T
Yeah its some 6x9s in the doors. Sounds alot better now. Thanks.
