why didnt you just buy the complete borgeson sliding shaft?After working with the Jeep shaft a little, I reached a point when I wasn't satisfied with the rubber isolated on the one end. So I cut the DD shaft off the stock shaft so that I could retain the spring tensioner.
One thing to note, I used red loctite on all set screws, and I also dimpled the spots where the set screws rest. This will ensure a firm joint between the shaft and the universal joint.
This is one of many options when it comes to making a steering shaft. Enjoy.
all that spring does is provide sliding tension, any steering play during driving is gonna easily override that spring.First, the borgeson shaft doesn't have a spring tensioner like the OEM shaft utilizes.
Second, I built this shaft cheaper than I could have bought one. Only spent 140 to build and I have enough 1" DD to mod my other caprice. The joints are also stainless steel and are much better, IMO.
Third, being a hobby, I enjoy fabricating and building it to my standards. With money, you can purchase anything you want. I have always liked the saying, built not bought.
I have an upper section with a good boot for $25 shippedjust notice my boot looks like that were the boot is open does any fluid go in ????? Ive never removed one before how hard is it
Pretty simple...one bolt on the steering gear end, one bolt on the column end...compress, and remove. Separate the ends, and install the donor end. Assembly is the reverse.I wouldent even know to to remove it lol
It's a 94 shaft. I also thought about combining the Caprice shaft with the Jeep but the way they join together is flip-flopped (male on top on one, male on bottom on other). Welding it could be an option.The interference has been noted in other threads. Did you get the early, or late (after 91) shaft. The earlier ones are a little smaller than the later ones. You could try using the upper shaft from the caprice with the lower shaft from the Jeep. I have not tried to use them together, but they might fit. Another option is to weld the bottom shaft of the Caprice part to the bottom universal of the Jeep, and use the upper half of the Caprice shaft with the welded up lower Jeep/Caprice shaft.
Yeah, I had the same problem with my Hookers (man, that sounds Pimp-ish) and probably mentioned this elsewhere on the Forum if not in this lengthy Thread somewhere.I just tried installing a Jeep steering shaft on my 9c1 today. Just FYI, it will not fit with Hooker headers. The upper part rubs hard on a tube.
