N
Nice Job!What size monitors did you use? (bet it was freaky cutting holes in your headrests..LOL)
Looks like I'm next....within the month- 2 headrests one drop down. Hope mine looks 1/2 as good.
O
Question: How hard is it to run the wires for headrest TVs? That is my main reason Ive never looked into putting tvs in my car. Did you do it all yourself? Looks tight!
Running the wire in the seat was very easy just taped up a hanger so it would not go through my leather, than taped the wire to the hanger and run it through the hole at the top, than with a little luck it went down to the bottom. or the hard way is to undo your seats at the bottom and us your hands.
Supaman's page
Looks good. What kind of video source are you using on them? Why didn't you remove the dome ligh and put the flip down pod in the place of it. From the pics I can tell you have dome and map lights on the pod or just dome lights. Either way you problably can do without the factory one and move the pod up some. Is it a swivel monitor.
Hey SC
The source is the kenwood 7 inch touch screen LZ-700w, and as far as not moving the dome light, the more I think about it I was a dumb*** for not thinking about removing it and put the flipdown in it's place. But I'll leave it so the drill holes don't show. Thinking about putting one more in the steering wheel like your but my girlfriend say four is enough, go figure.
Depending on where you drilled the screws at they may not show if you move it back some. I would do a little measuring on it and see. If the holes are in the middle towards the front you will be fine. Other than that great install. Tell your girlfriend that you will let her watch the steering wheel while you turn the corners.
