1 - 1 of 1 Posts
D
Just got my BMR rear lower control arms and front sway bar (2nd gen fbody replica). These are some NICE parts. Very solid. Well worth the money. The sway bar came with urethane bushings and everything needed.
Also changed my valve covers last weekend. The posts are correct. Driver side is easy and passenger side sucks. But it did cure my oil leak so I'm happy. I didn't have to remove transmission dipstick housing, but did need to remove the alternator. I put fel-pro gaskets in it (~$15) and they seemed like good pieces....
Also took apart the throttle body, that thing was FILTHY. Put the valve cover breather in so maybe it won't be so bad in the future... Anyone know the size of the bypass cap needed for throttle body connector to the deleted valve cover hose? I have bought several sizes and none fit exactly...
1 - 1 of 1 Posts
