The 1996 FSM (yes, the same FSM that thinks a 9 meter range is realistic) is a bit ambiguous on this. Anyone know for sure if it is possible to have more than 2 remotes programmed at a time for the keyless entry system? So could I have 3 remotes set up for the vehicle, or is 2 the limit?
I assume they all would need to be programmed at once, as per the FSM procedure.
