Hey have any of you ever tried to swap out all the exterior lights to LED? I have the electronic flashers installed. It did work until I turned the headlights on. So I made sure and swapped out all the bulbs to LED excluding the headlights, of course. Now the turn indicators are on and when I try to run a turn signal or hazards it kind of looks like a hyper flash condition. I don't know I may just keep it all incandescent and avoid the problems. Or should I install the load resistors? It did look really cool though.
any input would be greatly appreciated.
Thanks Rob
94 impalass 85K miles
coil over ignition, texas ram air, air pump delete, no resonators, excelerator muffs, 9c1 air dams, heavy duty oil cooler, many other goodies.
Thanks Rob
