large format midbass, full size horns, 2 infinitely baffled 18"s. Here I go again
Ive owned this car for over 5 years now, and have been working on the audio since i got it.
Im finally nearing completion of my first real build, and felt ike Id go ahead and post what I have at this point.
First, the equipmet
2 elemental designs 190v.2 18" subs. These are currently in a wall, and I am reworking this part in order to run them IB under a false floor, properly vented to the outside.
midbass are undecided, but Im working on a floor mounted, externally vented idea for a couple of 10 or 12" drivers
top end (800 hz +) is currently a set of id full bodied cd1ev.2 horns.
processing is an eclpse 8443 along with 2 of the cadence 1/3 octave eqs (not useing the eqs as of now, waiting until Im done before I add them in.
Amplifiers are passable right now, but an upgrade is immenent, I have an ed 9.1 (no problems here) on subs, a 9.2 on horns (also fine now) and a hifonics nemesis (serious noise floor issues here) which I want to replace with either 2 9.2s or 9.2xs for some more power available on midbass
sound deadening is a huge conglomeration of edead, second skin, raamat, and hushmat. I still need to do the front floors, and possible roof.
so onto progress
here my charging system. It consists of two iraggi alternators, a 180 and a 220. I get close to 300 amps as idle, if its cool outside.
I have 2 runs of 1/0 going to the rear, not because I need it for my current power demands, but because Im tired of replacing wiring, I figured this way it will never be an issue again
The runs to the back are external, run along the frame rail, supported every 6 inches by plumbers strapping and is covered in techflex. Its been this way for months, with no issues so far, but Im keeping an eye on it. I have some solid conduit I can use if I start seeing signs of wear.
I never have voltage below 14 when running, no matter what Im playing, including 0db test tones at full tilt.
heres the horns Ive been working with. I bought them for a hell of a deal, but the catch was they had been sitting in a shop unprotected for years, so I completely disassembled and cleaned them before using them.
Here are the horns, being test fit.
They arent quite to the outside, but without losing my e brake its the best I can manage yet
that stage height and width was awesome, even without processing, but I had some harshness. I have not had the horns in for over a month, as I ave been working on making a baffle in order to completely couple them with the dash, and making a bottom cover, so my floor mounted midbass wont be trapped by the horn bodies and the bottom of the dash.
Ive got the front baffle built, but it still needs some fine tuning, hopeflly next month Ill get that done up.
Thats most of it for now, but Ill show some of the plans I have
First, the equipmet
so onto progress
