1 - 11 of 11 Posts
Thats what I figured...but its nice knowing what the sepcs are. Im gonna be running 1.6 RR rockers so I'm trying to find the total lift.
Nick
Talk to Lloyd. He can spec a cam that works with your combo. LEx cams are custom made and often have different specs in different cars.
There is no set spec and he has used a couple different grinders(Joe O. before Bret) and they are not locked into one grind. I agree on the secret thing even as someone who chose another company I have asked folks to remove specs when they posted them. If you look around though you should find some ballpark statements as far as size.
Discussion Starter · #9 ·
Not "secret" but "Proprietary".
Lloyd asks everyone that purchases a custom-grind cam from him not to disclose the specifications. Most of us honor that request.
I think most of the time if you want the specs for an LEX cam and dont own one, you'll get it compared to off the shelf cam.
If the LE1 cam is for the 94'car in your sig, it would be a low/mid 220 duration cam with about .560 lift. Pretty similar to a CC 503 cam but a lil less duration.
If it is for your dads car, a GM 845 would be a good if he has stock gears and no stall.
Lloyd Elliott
972-617-5671
Eportworks.com
1 - 11 of 11 Posts
