1 - 1 of 1 Posts
so i purchased the correct flasher from superbrighleds.com long and behold the signals wont blink even with the led compatible flasher. i had load resistors on which work perfect with the original thermal flasher so i figured ill disconnect the resistor on one side and still no flash. so i put the original flasher and put the incandescent bulbs wont flash either on the left side but it will on the right side with the leds.
anyone can help?
1 - 1 of 1 Posts
