I was reading on the LED install for turn signals, I found out we need special flasher which I have. I wanted to know if the flasher will work with regular and LED's mixed or do I have to go full blown LED tails and fron turn signals.
I shoud work with mixed light bulbs because it will flash with "no" load on it. LED don't generate enough current draw to operate most standard flasher, so you have to use a flasher that allows it to flash with verl low current draw. That's why when you tow a trailer, you also have to a non-load dependant flasher. When you hook up a trailer, the current draw increases, making the flasher blink too fast. Hope that helps.
Thanks. I have been having trouble taking out the flasher, is there a special way of pulling them out. I have a 1993 Caprice.
It may be corroded in. You'll just have to pull on carefully. Try working it back and forth while pulling on it. No other suggestions, as it has the two tabs that hold it in.
