I just got some LED bulbs for my 1993 Buick Roadmaster Sedan, and popped them in, and discovered the signal arrows in the instrument cluster stay on all the time when parking/head lights are on. Otherwise they work excellent. I was wondering if anybody else has put LEDs in and had this issue? and is there a solution which doesn't require cutting up my wiring harness to put in a load resistor? I also noticed that the side signal/parking lamp dose not work unless you pop on the hazards, or put on the turn signal.
