This was copied from the old and long CAMS and CA smog post. I copied it because that thread is already 3 pages don't want it to get too long and disappear, but it is filled with great info.
· The following table was compiled by Jody Shapiro and
· is the single most comprehensive list of cams available
· for the 4th Gen LT1:
· Manufact Part # Duration Lift (1.5) Lift (1.6) Lobe Notes
· LGM N365 211 220 492 492 525 525 112 1500-6200
· LGM N365S 220 220 492 492 525 525 112 1800-6400
· LGM N385 220 230 480 480 512 512 110 3000-6500
· LGM N385S 230 230 480 480 512 512 112 3000-6500
· CompCams 08-304-8 210 220 500 510 533 544 114
· CompCams 08-306-8 230 244 510 540 544 576 114 heads, intake,
· headers,exhaust
· CompCams 230 242 510 510 544 544 112
· " CCA-215-224-14 215 224 499 499 532 532 114 2200-5700
· " CCA-220-230-14 220 230 510 510 544 544 114 2500-6000
· CompCams 215 224 499 499 532 532 112 FIS custom grind
· blower cam
· CompCams Extreme Energy Series
· " CCA-212-218-12 212 218 488 495 521 528 112 1200-5200 mild
· " CCA-218-224-12 218 224 495 503 528 537 112 1600-5400 stk conv
· " CCA-224-230-12 224 230 503 510 537 544 112 1900-5600 gears
· " CCA-230-236-12 230 236 510 521 544 556 112 2200-5800 hvy mod
· " CCA-236-242-12 236 242 521 540 556 576 112 2500-6000 all mod
· " CCA-206-218-14 206 218 480 495 512 528 114 Nitrous/Blower
· " CCA-212-224-14 212 224 487 503 519 537 114 Nitrous/Blower
· " CCA-218-230-14 218 230 495 510 528 544 114 Nitrous/Blower
· " CCA 224-236-14 224 236 503 521 537 556 114 Nitrous/Blower
· TPIS 700-134 212 226 483 520 515 555 112 ZZ9 cam for93-94
· TPIS 700-142 212 226 483 520 515 555 112 ZZ9 cam for95-97
· GM 450 450 480 480 93 LT1 (stock)
· GM 203 208 450 460 480 491 116 94-95 LT1 (stock)
· GM 205 207 447 459 477 490 117 96 LT1 (stock)
· GM 203 210 446 449 476 479 115 96 LT4 (stock)
· GM 10185071 208 221 474 510 506 544 112 ZZ3*
· GM 24502586 218 228 492 492 525 525 112 LT4 HOT
· GM(Crane) 12370845 214 224 488 509 521 543 112
· GM(Crane) 12370846 222 230 509 528 543 563 112
· GM(Crane) 12370847 232 242 539 558 575 595 112
· Crane 10hr0064 198 206 480 480 512 512 112
· Crane 104124 214 220 452 465 481 496 112
· Crane 104121 204 214 429 452 458 482 116
· Crane 104125 208 214 438 452 467 482 112
· Crane 109621 214 222 498 509 520 542 112
· Crane 104141 218 218 498 498 531 531 116
· Crane 10HR00013 214 222 488 509 520 543 112
· Crane 10HR00017 214 218 488 498 520 531 114
· Crane 215 224 499 499 532 532 112 FIS custom grind
· blower cam
· Crower LM-00402 219 227 498 518 531 553 108
· DRM 222 230 508 528 542 563
· LPE 74211 211 219 499 525 530 560 112 1600-5200
· LPE 74216 213 219 462 471 493 502 112 1600-5200
· LPE 74219 219 219 525 525 560 560 112 1600-6200
· Lunati 50160 213 218 446 468 475 499 110 1500-5300
· Lunati 50155 215 218 489 503 522 537 113 1500-5500
· Lunati 50156 232 242 510 525 544 560 108 2000-6500
· Lunati 50162 242 252 525 540 560 576 108 2200-6800
· RRA1-218-224-A114 218 224 503 504 537 538 114
· SealPwr 222 232 478 497 510 530 114 KenR
· MTI 210 220 500 510 533 544 114
· MTI 230 244 510 540 544 576 112
· * Requires longer camshaft dowel pin for use in '95+ LT1's
Thanks guys those are both much easier to read.
Blue Wail, have you decided which of those for your 306ci?
