1 - 13 of 13 Posts
H
did anybody had this problem, I guess from slamming my sounds. the first pic is from inside the trunk. and the next two is behind the lic. plate.
T
Oh wow, damn. That's crazy. That's why you gotta put all that bass in the cabin. :D
F
are you guessing that happened from you box slamming into that section
are you saying spl made that happen
? what sounds were back there
H
my box is lock down its not going any where.and my rear deck is also ported where my 2 10" used to be. all I can say is I was getting ready for a cruise and notice my trunk look partly open. so I tried to close it and it wouldnt stay close all the way. what is funny is that my freind told me that it wasnt pushing as hard as it used to, some of the bass was exiting out the back
F
i really don't think your amps and sub pressure did that
i could be wrong but don't think so
could it have been anything else that you can think of
how many 10 " subs are in your trunk
how much power are they using
H
All Im running is 2 10" T1 and 1000 watts with a ported box.
F
if it is a t10001bd @1 ohm than it is closer to 1500 watts
but that aint breaking nothing
sorry no clue how that happened
but i am using 2 15" t2 and a T20001bd in the impala right now
thats 2850 watts
i was using 2 600 watt amps but switched to a 20001bd
and i am gonna get a 2nd t20001bd and put 1 on each sub
that 5700 watts and i am not concerned about any damage
gotta be something else
F
take a pic of your trunk i wanna see your set up
if you will be so kind
K
Discussion Starter #13
I had four 15s in a '84 Park Avenue. I had two a box and the other two bolted up facing the two in the box. I had all 4 were 8 ohm subs. I had them bridged down to a 2 ohm load. I had them them on an Autotek 330MXI. I broke the entire latch on the truck......TWICE. It was exactly like his. But, of course, mine was much worse than this. :D
1 - 13 of 13 Posts
