and I don't want to make one. I looked all over and couldn't find a place to run the power. What have you guys done? I guess this is where a rear mount battery comes in handy cwm1 TIA
i ran 2 0 gauge wires through the factory grommet on the driver side, along wtih a single 8 guage wire for the headunit through a drilled hole and grommet on the passenger side. that spot is plenty for a single 4 guage or smaller. if you got bigger ones, go to the grommit on the driver side.
here is where the two zero gauge came in:
here is where i put through the single 8 gauge:
hope this helps.
b
ran mine from battery down corner by under hood fuse panel then went inside the frame down by the passenger lower fender.ran it all the way inside the frame to the trunk then drilled a small hole between the frame and gas tank up into the trunk.
