Hi, im looking for the front drivers and passenger side floorpans from the firewall seam area to right in front of both seats. Dont need the rocker panels or tranny tunnel. I know there is a bunch of people cutting up cars and parting them out. Let me know if u can help..Thank you...
You picked the hardest part to cut out...the seam at the front. There is a body mount on the outer sides of part of each panel, and they are a bugger to cut. I am going to the yard on the 5th of May, and I will see if I can get them for you. You are probably looking at $50 plus shipping.
Actually i only need the sheet metal, it is spot welded to the framing for the body mounts, but if its easier cutting out with the framing thats fine.
Ok, had to cut my floorpans to access the body mount nuts that the cages rotted. Gonna use the pans to cut sections out to repair mine. Thank for the help, let me know if the pans are good and when u get them out.
