I have been driving newer cars for the past two years and since putting my caprice back on the road tonight, I'm noticing how loose the steering is, feels as if the steering wheel moves to easily. what parts should I replace to rremedy this minus a full front end rebuild.
you just said it bro get the front end rebuild and dont worry about nada lol. best mod ive done to my steering.
how much was the install, and did your neighbor do it.
Newer steering is often stiffer than older cars. Yours may be just fine. My 92 OCC is really light. My 91 is actually heavier than the 92. Check the parts for tolerance before you just replace parts.
I have a smaller 14 inch steeing wheel on my 91, so that could have an effect on the work I have to do to turn it.
other shops wanted 600-1100 lmao!!
your neighbor did it? how much and where you get your kit? I want to do this before I take the ride on the highway.
loose
there is also a nut on top of your box that you can loosen and tighten up a bit,my steering was loose after i rebuild my front end couldnt figure why after all i had done still loose and old guy told me this and walllla no more loose steering just tighten go for a ride if satisfied leave it if not do it again until your comfortable hope this helps
