What makes you think you can....?
Same way you reset the red battery light in the dash of a 96'.......purchase new battery.
-ALF out....
? I am a bit confused? If the low oil light is on then either you are a) low on oil or b) the oil is at the proper level and either the oil level sender in the oil pan is bad, the wiring for it is, or the circuitry in the dash is bad. The simplest thing to do, if the oil level is correct, is to replace the oil level sender, simply unplug it, use a 1 1/8" socket to remove and replace the sender then plug it back it(do it at the same time you do an oil change). - Peter
Or does he mean the oil change reset light?
