It has 79000 on it runs good but it says it has low pressure it make a little noise in the motor but do t really know what it is also just changed the oil and the next day it was low btw I am using the stock gauge
The pressure senders have been known to go out on these cars. I am using the somewhat popular truck sender and it helped me a bit. Mine use to dip into the red, but is now in the safe area. Did you change oil weights on your last change? If you really want to be sure, you might also want to hook up a gauge and see what its actually reading.
