Hello All. I'm in the process of "almost" completely rebuilding my front suspension. I have loosely mounted my new Moog Prebuilt Upper and Lower Control Arms. My question is on the lowers. It took a bit of pushing while swinging up and down to get the lower bushings lined up in the frame hinge. I greased the bushings and hinges. I put the bolts through the hinges and loosely threaded the nuts on the bolts. My question is this-My new lower control arms seem tight at the rubber bushing as in their pressure just enough holds the lower arms up in the air if I push them up. The driver one seems a little tighter. Is this tightness a normal thing from new bushings (new control arm)? I painted the hinges So that's a little added but I think the result would of been pretty close the same If I didn't paint. I'm guessing it's a silly question as the spring probably sees no added resistance aside such a heavy vehicle all assembled. I just have to ask the question so I'm very sure my new bushings are not at risk while seeing this resistance and after all the work done and tightened up. And I've heard stories of people saying their front ends were not returning to normal height after they seemed to do everything correctly. Im noting the FSM says to install spring isolators top of spring (I'm waiting on a pair of Moog) "and" FSM says put tape on the lower end of the spring, following by covering at least some of the first drain hole none of the second. I'm guessing the tape keeps the noise down and prevents scratching of the protective coating on the control arm minimizing the introduction of corrosion. Thanks
