·The other night I was doing the front swaybar delete on my Caprice (was planning on going ot the track, but it's closed
) and I noticed something. After I disconnected the endlink on one side, that side end rose almost an inch. After I did the other side, it evened out. I looked at the design and figured that the swaybar pulls the suspension up a bit lowering the car. So removing the endlinks let the car raise up a good bit.
Well, I'm going to put the swaybar back on the car. Turning is SCARY with no front swaybar (no rear one either). And the car floats evenmore (factory FE1 "soft ride" package). I've wanted to lower the Caprice to about where the Impala is stock.
So, I look at how the endlinks are done and start thinking. I wonder if I were to trim the spacer bar that seperates the bushings if it would lower the car a bit? I know it would mess up my alignment, but it needs to be re-aligned soon anyway. Plus I rotate the tires fairly often.
It seems that it would work. It's basically a free mod and is cheap to put back to stock (just find a new tube to replace the old one). And it looks effective.
Heck, I'm wondering what would happen if I were to totalle eliminate that bar altogether?
