Well the message title says it all...
I have the air ride air bag kit on my car.
I also have the HO rear sway bar..
And J&M extended rear control arms.
If I run the bags a little low on air the sway bar will contact the exhaust when I hit a bump. Is there an easy fix for this?
I am assuming bending the exhaust out of the way is the best option.. (It seems to stick down excessively to get away from the heat shield.. Maybe bending the pipe and using heat wrap would be better.)
I had the same set-up exept for a HA bar and it would hit. With any extended control arm the exhaust pipes will probably rub. A local muffler shop bent mine out of the way for $20. While it was on the lift, I grabbed the bumper supports and moved the car up & down to simulate the travel and they bent it out of the way.
**Keep an eye on those J&M lowers with that big sway bar(I believe the HO and the HA bar are the same size). One of my J&M lowers broke with everday driving!!**
