R
Can anyone tell me which is the easiest and least expensive way to lower my Caprice?
T
You can cut the front, but the back is progressive wound, smaller diameter at top and bottom, means shouldn't be cut. I have seen people put stock Camaro springs in these cars, but it makes the ride really soft, more so than stock. You can get a full set for around 200.00 or jut buy the back springs and cut the fronts.
D
To play it safe order up a set of eibach springs
CHEVROLET, Caprice, B-Body, 6 Cyl. & 8 Cyl. - 1992
(Exc. Wagon)
Product Front Rear Comments Part Number
PRO-KIT 1.2 in 1.2 in Varies by engine size and or model. 3832.140
J
rodalt2,
Not sure how low you wanna go, but a set of stock SS springs will drop you 1 to 1 1/2 inches. Also, if you buy a lowering kit for an SS then it is gonna be really low compared to your stock Caprice ride height.
JP
I bought a set of used, stock Impala springs off this forum.
They cost me $80.00 for all four.
I did cut a half coil off the front springs and I'm very happy with the results.
Put the word out your looking for set. Someone may have some.
Later,
Bob T.
