quick question here.....
i want to lower my 9C1...but i still want it to have good bite at the track...will using lowering springs (which probably are a lot stiffer) hurt my traction???
which springs do you all recommend??
thanks a bunch...
lowering springs should help as long as there stiffer. keeps more weight to the axle.
lower the profile on your tires will hurt your bite.
the lowering springs might give you less options on drag slicks if you use them
