Nah u got it homii. I like good ?s that stay on topic. This is a good 1 to ask. So if I change my springs I should change my shocks to then huh? And wut about the struts?ss springs , and whats a good shock to get...? not trying to jack this but im in the same boat
Whatever you do, do not take this advice.and heat up the rears til theyre even
Thanx for the advice this is what I needed. Sorry about the question on struts! Lol. As you can see I'm no mechanic and don't know too much on suspension but this right here was very helpful. Thanx again. Oh and lmao on the heatin the spring qoute!Our cars do not have struts.
If you replace the springs you do not NEED shocks, but it's a good idea. You will notice a much bigger handling difference.
Get the Bilsteins, you won't regret it.
Impala suspension is not longer. They are physically identical other than the spring height. The Impala axle is wider but that's it.
SS springs are a great way to lower the car on a budget. Hotchkis/Vogtland are an even better way if you want a more aggressive stance and improved handling.
Ok that sounds like a plan. Where are some spots to buy that? And you mean for the rear end right? And as far as the control arms lower or upper?Like Fishah said, the control arms are the same length but the axle is narrower. So get some Hotchkis extended control arms and some 1" wheel adapters and post some pix!
Here are the places that I have found with the most inexpensive prices, if anyone has some better recommendations, please advise. These are just the opinions from someone who is relatively new to B-Bodies.Ok that sounds like a plan. Where are some spots to buy that? And you mean for the rear end right? And as far as the control arms lower or upper?
Thanks again man this is some very helpful info. One more ?... lol. Don't be mad I just like to get all the great info provided here. The wheel adapters. Are they to make the rim and tire stick out more or what exactly is it for? I'm assuming the suggestion you gave me is what you have done to your car and if so post some pics so I can get an idea of what it looks likeHere are the places that I have found with the most inexpensive prices, if anyone has some better recommendations, please advise. These are just the opinions from someone who is relatively new to B-Bodies.
For the extended control arms, look here for details and part numbers (the BMRs are also a good choice):
http://www.bmrfabrication.com/ImpalaSS.htm
Some will say that you need to extend your drive shaft but I have been told by various shops and BMR techs that you do not have to (provided that you don't do a lot of racing).
While you can order them from that site, I believe summit is cheaper on shipping, just make sure you get the right part number:
http://www.summitracing.com/search/Year/1995/Make/CHEVROLET/Model/IMPALA-SS/Department/Chassis-Suspension/Part-Type/Control-Arms/?Ns=Rank%7cAsc
Go here for the shocks:
https://www.allshocks.com/bilstein/html/show_shocks.asp?make='CHEVROLET'&model='Impala%20SS'&year='1995'
HDs for the SS stock height and Sports for Eibachs, Hotchkis, Sprints, etc lowering springs.
I have yet to find a place that sells the wheel adapters for cheap, so if anyone knows a place, please let me know.
Peoples please post a pic of this if you have it so I can get an idea. I would like to see pics of the ss rims with the stock ss springs and some lowered.Like Fishah said, the control arms are the same length but the axle is narrower. So get some Hotchkis extended control arms and some 1" wheel adapters and post some pix!
