T
If you can lower an Impala SS 2" on 18's and it is allready 2" lower than a caprice. Can i use a set of 2" lowering springs for an Impala on my Caprice and lower it 4" on 18's? Will the springs from an Impala fit a Caprice?
Ill answer the easy one; yes the springs will fit. Someone else will have to answer the more difficult questions for you..
Matt
if you order drop coils for an impala and it is going on a caprice add 2 inches to the drop. example, if they advertise impala 1.5" drop coils, it would lower a caprice 3.5" inches. The springs are interchangeable. If you only want a 2" drop on a caprice, locate a set of impala coils.
T
Thanks for the info. I will try to locate a set of stock springs for an Impala.
