Glad it worked out, but remember, it should be temporary till you can get the proper tune. Grounding pin 55 in a truck tune with a/c type set at “analog cycling”, tricks the pcm into thinking that the pressure switch, not sensor, is okay and can cycle the compressor. Thing is, it will never turn off and cycle, and both fans will not come on, only one. Best thing to do is definitely get a f body base tune and work from there. And for anyone who didn’t see my swap post and this thread is more suitable for this info, wiring should be as follows:
High pressure switch
Gray wire - blue - pin 45 : 5V reference
Red/black - red - pin 14 : pressure signal
Black - blue - pin 60 : low reference
(Different low ref pin can be used here. My harness happened to have this slot empty)
And the rest of the wiring, coming from stock LT1 harness and relays
A/c Request - blue wire - red -pin 17
Ac clutch enable - green - red pin 18
A/c relay - green/white - red pin 43
This is for RED/BLUE PCMs only! Also A/C type must be set to “analog”. Green/blue pcms and up require more work but can be done. Hope this helps others out too!
