So who has trod this ground before me? I'm having "issues". Believe me, I've searched here, several other forums, and google. I've already gotten a pricey Quicktime LS- to Gen1 adapter bellhousing. Now, I find the nice Z06 LS7 flywheel I got with the transmission deal has to be changed to a regular old 2pc flywheel.
I'm ok with that, and according to a popular online partshouse tech I should be able to reuse my LS7 press/plate and disc. I'm not seeing it as so easy. Every Gen1 flywheel I see illustrated is completely flush across and does not have a spring recess that is clearly needed for the LS7 disc I have.
I don't mind ditching the whole LS7 clutch setup, but maybe you can see where this is going. Am I going to find when going to an old-style Gen1 press/plate setup that I can no longer use the LS- type pusher slave cyl., and that I have to go to either an LT- puller type slave or even a mech. Z-bar?
I want to see this go together, I'd just hope not to accumulate a bunch of parts and find it won't work anyway.
