1 - 20 of 20 Posts
I have a couple LT1s that I stripped down...All are 94 LT1 motors and running great when parted.
wiring harness: $125
PCM: $65
Opti: $50
ICM and Coil: $40
ICM and MSD Coil: $50
Intake: $40 (have 2)
Intake (powder coated red): $60
MAF: $25 (have 3)
Alternator: $35
Smog pump: $25 (have 2)
AC Compressor: $50
PS pump: $40 (have 2)
AC lines: $25
Throttle body: $35 (have 3)
Misc Sensors: $25 each
Opti with MSD Cap: SOLD
Accel Injectors with polished fuel rail: SOLD
Anything else in the pic is available, or anything else you can think of that would not be needed on a carbed LT1 will be available. Pm me with what you need.
Doug
...All are 94 LT1 motors and running great when parted...
Opti with MSD Cap: $75
Gen-1 OR Gen-2 Opti???
(Yes, I know it's a 94, but...)
If the ac lines arent burned through or cut. I would like them
i really need the 90 degree rubber hose that goes between the hard line on the intake to under the throttle body. I dont need the tube, but ill take it if i have to.
Got parts today, great turnaround, good seller... however i guess i still was not clear on what i needed...
I need the 90 degree rubber hose, that goes between the hard line to the intake under the throttle body... these parts are from the side...
Discussion Starter · #18 ·
I'm away from home tonight, but I will get on that tomorrow night, sorry for the miscommunication, I will drop you a PM with pics this weekend just to be 100% sure this time we have the right part. :)
Thanks for the kind words otherwise,
Doug
I'll take the 2nd set of A/C lines... Provided they aren't burned or cut as well... Let me know where to send paypal to.
Thanks!
1 - 20 of 20 Posts
