Swapping my lt1 out of my 95 impala into a 4 door 87 cutlass. The radiator is to wide for the cutlass. Will need to get another radiator to fit cutlass. Since the lt1 has reverse cooling will I need a radiator with engine oil cooler or can I just get a a 2nd or 3rd row radiator with fans to handle capacity.
Check this thread out a few posts down. I have deleted the engine oil cooler from my old 94 Fleetwood and my current 96 Roadmaster. I got the aftermarket kit for the Caddy and went with the L99 adapter for the Roadmaster. If you use the L99 adapter you can run a factory oil filter for an LT1 B/D body. If you use the aftermarket one I think I used a PF454 filter due to clearance of the cat.
You can use a regular radiator and plumb it like you see in these posts.
http://gbodyforum.com/viewtopic.php?f=8&t=16104&start=30
