I asked bryan herter about this when i got my pcm tuned and he told me that he desensitizes the stock KM and with your mods, similar to mine, you will probably not get any knocks after a pcmforless tune. I ran my car with datamaster and never picked up a single knock.is it worth it with the mods i have to install a LT4 KM
also is it better to have a dyno tune or a pcmforless tune?
Yes. A LT4 KM is ALWAYS worth it!!! (Any mod/power level)is it worth it with the mods i have to install a LT4 KM
The LT4 KM was needed because the noise of the roller rockers used in the LT4 was causing some false knock retard. With stock rockers you'll likely see no benefit.is it worth it with the mods i have to install a LT4 KM
A dyno tune by Bryan would be an even better option.also is it better to have a dyno tune or a pcmforless tune?
Had Bryan Herter from PCMFORLESS DYNO Tune my vehicle.A dyno tune by Bryan would be an even better option.
Its in the pcm under the access door. It looks identical to the stock lt1 KM except the first set of numbers on top of it should be 16214681, if its the lt4 KM.sorry for my ignorance but im thinking your talking about the lt4 knock module.....like 9 yrs ago i did the whole gm hot lt4 kit and i cant remember if i changed this piece- where or what can i check to see if ive already done this?
thanks in advance everybody
