I do not see what is to be gained by general observation and discussion. The "Vette" starter made by Denso was a good product. A gear reduction starter made by company "X" may be better or worse than the stock LT1 starter. A good new or rebuilt LT1 starter may be better or more reliable than another "Vette" starter that may not be a Denso.but will start a "Vette".
The Denso was a quality part that used less electrical power and delivered more crank power. If you do not get a Denso you need proof it has the same qualities. As the "Vette" was low production there are fewer and fewer real Denso on the market and more knock-offs.
The Denso starter and alternator on my 92 dodge truck are OEM and work after a life in the federal park service. They wore out the driver's door hinges. I have replaced the solenoid contacts (under $10 CD) due to it's high use. I doubt a knock-off could handle the high use for long.
