I like this calculator:Got with my engine builder yesterday........this is what we have going:
Head Volume CC:.... 56cc
Flat-top Pistons:...... 5cc valve reliefs
Deck Clearance:...... .004"
Gasket Thickness:... .030"
Quench:............... .034"
Cylinder Bore:........ 4.040"
Gasket Bore:.......... 4.110"
Stroke:................ 3.875"
Rod Length:............... 6"
ABDC @ 0.050 Lift....... 64*
Plus 15 Degrees
SCR 12.91:1
DCR 10.36:1
Using the calculator at the below link:
http://www.kb-silvolite.com/calc.php?action=comp
If anyone has a "better" calculator.......push it my way!
KW
http://www.not2fast.com/turbo/compression/compression.shtml
I got 13:1 static compression and 9.1:1 dynamic compression. It is slightly on the high side but can certainly be tuned for.
The assumption, however, is that the seat-to-seat IVC value equals tot he .050" lift IVC + 15 degrees. It may not be true with solid roller cams as they are more aggressive. So the dynamic compression would end up higher due to a smaller IVC angle.
