Well, I just got my car running. Had a few other posts regarding small issues and was able to get fixed with help here so I'll try again.
Installed a used tranny with aroung 120k miles. I changed the front pump and installed a T-Go HD-2 kit before install. Also installed a Yank SS3600 stall. I got my PCM back from pcmforless and decided to go for a drive.
Seems like I am starting in first with no shifting at all, regardless of which gear I choose with the shifter. I get up to about 50mph and just start bouncing off the rev-limiter- ~6200. This happens at part and wot.
TPS is .67 @ idle and max is 4.33 . I adjusted this for the 58mm tb before the tune. I am also running a comp 503 cam.
Any help would be appreciated, I will likely end up swapping the tranny but want to make sure its not something with the harness or pcm first.
I may be forgetting something so ask and I will try to answer.
