So, hypothetically speaking, what if you had 2 different Tunes on 2 different PCMs? Then what if you were able to make a splitter cable that worked as a sort of relay. Instead of off/on, it would change which input would send to the car.
And once you were able to flip it back and forth, you take it for a drive. If you are driving along an empty road and put it in Neutral, shut the car off, coasting and flip the splitter cable so that the other PCM is "active."
Could you turn the key, slip it back into drive and roll on with your 2nd Tune?
Anybody know if that could even work? I mean it sounds functional.
