Does the factory cam in the B-body L03s have the lobe for a mechanical fuel pump?
pull the block off plate and stick a rod in the pushrod hole and get a helper to turn engine over. i have seen either or for the fuel pump lobe on the TBI/TPI stuff.
NOTE: I have also seen blocks with a block off plate and the pushrod hole NOT drilled, so I would check there first.....
Sounds like this is what I'm going to have to do. Thanks GM for never being consistent about anything ever :rolleyes:.
