I putting together an engine I had apart for many years...and have misplaced a few parts such as
1. rear main seal carrier
2. timing cover bolts
3. oil pump bolt
4. A/C compressor
5. oil level sensor
6. rear main seal bolts
a few more things I'll probably realize when I get a little futher
You should consider getting both of them new. The oil level sensor is cheap, and the compressor is wear sensitive. Remember to replace the other suggested components and thoroughly flush the system.
