Have a 2011 chevy impala, it just quit. No fuel pressure. The 15 amp fuse that is supposed to have constant 12 volts, is missing the 12 volts. I can't find anyone that knows where that fuse gets its 12 volts. The diagram I have only says hot all the time. This is the 15 amp fuel pump fuse that is fed through the relay and on to the pump.
The fuse is good, just missing the 12 volt source
Any help, and thanks.
Found problem, the schematic I had from the net showed the constant 12 feeding the fuse when in fact the constant 12 fed the relay and then on to the fuse.
