Well you can only see the corner of mine here when I was installing my double din
But of course, I have a pioneer head unit which has a wired control input, Pac adapter SWI-PS, pain in the a$$ to program, just by you have to change the settings fast or it doesn't learn them, and works like a champ ever since day one. I had a factory unit in my car for awhile wired to the steering wheel and worked perfect as well.were you able to connect the audio controls on the monte steering wheel?
I actually don't know the year, but yes it was a direct fit with no customization but there is this yellow peice with airbag wires and wires for the radio controls that you have to get also, I think it's called a clock wheel, but even the airbag is the same wireing as the B-bodys. And I don't have the controls working because like 94mi9c1 was saying you need the PAC adaptor which I believe is a different model number that I need because mine is alpine and his is Pioneer. also if you wanted the wheel to work with your radio, I believe you have to get the radio from the car you remove the wheel from because there is a green signal wire that isn't on the b-body radio wire harness.305classic... few questions cuz...
1. what year is your monte wheel from?
2. was it a direct fit like the one I did from a 97?
3. do you have the volume controls to work on your radio?
Yeah it is the clock spring actually and you will need the harness that runs through the column, I just bought the whole column from the Monte I ripped mine from for 25 bucks, but I usually get pretty good deals at the yard here in town.I actually don't know the year, but yes it was a direct fit with no customization but there is this yellow peice with airbag wires and wires for the radio controls that you have to get also, I think it's called a clock wheel, but even the airbag is the same wireing as the B-bodys. And I don't have the controls working because like 94mi9c1 was saying you need the PAC adaptor which I believe is a different model number that I need because mine is alpine and his is Pioneer. also if you wanted the wheel to work with your radio, I believe you have to get the radio from the car you remove the wheel from because there is a green signal wire that isn't on the b-body radio wire harness.
Is the radio in the Monte Carlo a direct swap for the Caprice/Impala radio?I actually don't know the year, but yes it was a direct fit with no customization but there is this yellow peice with airbag wires and wires for the radio controls that you have to get also, I think it's called a clock wheel, but even the airbag is the same wireing as the B-bodys. And I don't have the controls working because like 94mi9c1 was saying you need the PAC adaptor which I believe is a different model number that I need because mine is alpine and his is Pioneer. also if you wanted the wheel to work with your radio, I believe you have to get the radio from the car you remove the wheel from because there is a green signal wire that isn't on the b-body radio wire harness.
SWI-JACK, I posted this previously if he has an Alpineif you have an aftermarket radio in it you can still get the controls on the steering wheel to control your radio...
i have an alpine. i would have to buy a pac box... it retails for $100 but obviously you can get them shipped to your house from ebay for around $35-40.
i will get back to you on the actual model name.. i am on my blackberry and don't have the link saved.
now the search is on for me to get a 00-02 monte steering wheel. I WANT THIS MOD DONE BAD!!!
How hard was it to dye your wheel? Did you do it yourself? If so what did you use? it looks good- 1995 Monte Carlo Wheel
- Dyed to match interior
- All controls fully fuctional (except Pre Set button)
