Just a note to let y'all know I am very happy with this coil spring (and "Boxy" Bilstein shocks) in the front of my '95 Cap wgn. Firm but not jarring, much better control than stock.
When I bought these springs almost a year ago, the listing I found was for a '78 Olds 88 with 350 Diesel engine, and A/C. here are the specs:
Spr # Moog 6446
Inside Dia 4.03
Bar Dia 0.765
Install Height 10
Load rate (lbs) 3325
Spring Rate (Lbs/in.) 514
Free Height 16.77
After installed and settled, about 1.5 coils had to be removed (about 2 inches). Fender is now at 28" (with 255/45/18s).
Cool, thanks for the info. Any chance of posting a closer pic, or from a different angle?
I am thinking about going with Moog 5552, which is almost identical, and probably not cut it at all.
http://www.moog-suspension-parts.com/proddetail.asp?prod=MOOG-5552
Coil Spring Dimensions
End 1 Type End 2 Type Inside Diameter Bar Diameter Install Height Load Spring Rate Free Height
Square _____ Tangential ____ 4.030 _____ .765 ______ 10.50 ______ 3025 _____ 543 _________ 16.19
