1
The service manual calls for a specific distance from bolt hole center to top of arm.
Does the Moog problem solver, have an adjustment ???
THANKS
JIM
L
This isn't really an answer, but I just bolted the idler arm on out of the box. Still alive.
A
The Moog is within that spec, out of the box.
Only reason it is listed is that the OEM idler arm, besides using a cheesy-aSS design
, is adjustable in that dimension by simply unscrewing the arm from the mount. Net result is an arm that sucks and does NOT last long under loads (i.e. wide tires), but can be used in multiple applications besides ours by simply "adjusting" the arm.
L
The Moog "enhanced design" is PN K6187T.
Bolts up, out of box.
