I am looking for the part numbers for the upper and lower front control arm bushings and the upper and lower ball joints. My lowers are 5/8".
thank you,
Gary
Below is a list from an earlier post after a search. If this is not enough, do another search in suspension using moog as the keyword.....ton of posts.
"FOR ITEMS THAT ARE AVAILABLE AS STANDARD & "T" VERSION, I AM LISTING THE
"T" PART ONLY. I AM ONLY LISTING THE HD BUSHINGS, ALSO. Note that Moog
"M2 Technology" and "T" components have the same improvements. Prices
are as of 27 March 2000. All prices are each.
P/N Description Price
K6187T Idler arm HD Problem Solver $23.45
K5208 Upper ball joint $15.93
K6145T Lower ball joint, 9/16" (stock Impala) $19.06
K6141T Lower ball joint, 5/8" (HD upgrade) $23.60
K6210 Upper control arm offset shaft kit $36.38 (1/side)
Includes K6198 "stock" bushing (use K6409 instead)
K6409 Upper control arm bushing HD (kit, 4 pcs) $28.94 (1/car)
K6419 Lower control arm bushing HD (kit, 4 pcs) $37.49 (1/car)
DS899 Center link, standard Caprice/ImpalaSS $63.42
(no steering stabilizer)
DS1405 Center link, Buick with strng stabilizer $83.45
(for TSB upgrade)
ES2019RLT Tie rod, Inner HD $19.80
ES2020RLT Tie rod, Outer HD $18.34
ES2004S Adjuster sleeve, tie rod $ 8.29"
