P
I changed out my centerlink with the Moog Today, and I noticed a big difference in the handling and steering, probably because the one that was on there was shot anyway. Just thought I would tell you about my experiance with old and new.
Z
Thanks for the info. How difficult was the change? Did you have to get a reallignment afterward?
-Tim
Anytime you change anything on the front end you should get re-alligned, the slightest change in something will alter the geometry and might make the car feel "off" might make a tire or 2 wear too fast, who knows, its worth the cost of gettingit alligned, plus if you bring in the specs off the B-Body.net site, you will like what it does.
P
it wasnt that hard to change just had to rent a small puller for the tie rods from auto zone to pop the joints loose. other than that simple and easy, 30 min. job.
